os2rob
#1 Posted : Thursday, June 17, 2010 5:12:21 PM(UTC)
os2rob
I have an Urbina Design Thermoelectric wine cooler. The unit is plugged into the electrical outlet. Switch is on, but the interior light is off. The fans aren't working. Any ideas how to troubleshoot and/or repair?
#2 Posted : Friday, June 18, 2010 4:17:48 AM(UTC)
I tried to find some tech info on this unit and had no luck.
Hopefully someone else will be able to provide more info.
Check on the unit, in the unit and the operator's manual to see if you can find a wiring diagram.
It sounds like you have blown a fuse in the unit.
From what I did find this unit uses a peltier device for cooling.
I do know that most peltier units have a thermal fuse which blows if the peltier gets too hot perhaps this is what has blown.
