Rank:: Member
Dryer was running no heat. So i replaced heating eliment A complete unit. And now the motor run but it was running before i unpluged to do the work please please help
A model number may help others help you.
Also And[COLOR="Red"] now the motor run[/COLOR] but it was running before i unpluged to do the work please please help Is the above in red just a typo should it read "now the motor does not run" |
THIS FORUM IS DEAD!!!!!!! |
Rank:: Member
Originally Posted by: denman A model number may help others help you.
Also And now the wont motor run but it was running before i unpluged to do the work please please help Is the above in red just a typo should it read "now the motor does not run" IT DOES Make hummig sound
Perhaps you knocked a wire off or loosened it from the moto'r start winding |
