Hello all, I got a question... my old sub zero 30" 511 model is looking a bit dated with its wood panel. Does anyone know if I can swap the door for a newer glass model door and the bottom drawer with a stainless panel to make it look like a current generation Sub-Zero BI-30UG? (Sub-Zero BI-30UG Glass Door Refrigerator/Freezer: Sub-Zero Built-In Refrigeration) Are the doors a direct swap? If so does anyone here know where I'd get the part numbers or who to order from?? mike_toronto2 attached the following image(s):
well, i just got off the phone with Sub Zero parts specialists. They said that the 511 model never had a glass door option but the replacement 611 did. However the 611 glass door has a heating element that the 511 doesnt have so even if I DID do a retrofit, the door would just fog up without the element :/
does anyone have a way around this?
