Chris33
#1 Posted : Thursday, June 17, 2010 10:25:37 AM(UTC)
Chris33
I have a dryer that has begun to act up. It often doesn't start or requires holding down the start button a few seconds until the motor really engages. Sometimes the motor doesn't engage and it won't respond to the start button at all. Then, after a few minutes, if I come back and try again, it starts. I thought it was a bad starter, but now additionally, when I do finally get it to start, it sometimes quits in the middle of a timed cycle. The timer checks out fine. Could it be overheating? Could the thermostat and the starter have gone up at the same time?
#2 Posted : Friday, June 18, 2010 3:50:55 AM(UTC)
Your model number is short several digits.
Kenmore numbers are usually 3 digits. then 7 or 8 digits.
Kenmore does not make any thing and the first 3 digits tell us who actually made the unit.
This gives us a better chance at guessing about the tech info for the unit.
[COLOR="Blue"]Could it be overheating?[/COLOR]
My guess would be that you had/have a motor problem.
This then gave you a low air flow through the unit and it has now blown the motor's thermal fuse (usually mounted on the blower assembly along with the cycling thermostat.
[COLOR="Blue"]Could the thermostat and the starter have gone up at the same time?[/COLOR]
Doubtful but anything is possible.
Chris33
#3 Posted : Monday, June 21, 2010 11:19:32 AM(UTC)
Chris33
Thanks for the response. Sorry I was shy a few of the numbers. After I started to smell a slight burning scent when I was trying to work on it, I figured it was probably the motor. The dryer is 11 years old and has done a great job but given all the problems, it is now time to put out to pasture. We bought a new Kenmore with a moisture sensor that should do us fine. Hopefully we'll get 11 years plus out of this one! Thanks again!
