ggrizzlys
#1 Posted : Thursday, June 17, 2010 6:03:56 AM(UTC)
ggrizzlys
When freezer goes into defrost mode ice forms around drain hole blocking the drain hole. over serval times defrost water runs out on bottom of unit . When this happens freezer quits working at its full capacity. I then have to unblock drain hole by chipping the ice that has formed at bottom. Any solutions. Ggrizzlys
#2 Posted : Saturday, June 19, 2010 4:35:23 AM(UTC)
Check that the drain hose is clear.
Could be it is partially obstructed or there is dust in the drip tray slowing down the water flow.
You may want to try flushing it with a 10% bleach solution. A turkey baster works when doing this. This should kill any crud growing in the drain and then flush it out. Flush some let it sit for 15 minutes and do it again. You may have to do this several times. Just be careful to not overflow the drip tray and wear old clothes unless you are into tie dye.
As a last resort you could try the following. I personally have never doe this but many others have. Take a piece of 14 or 12 gauge bare wire, wrap it once or twice around the heating element (wrapping it around a fin just above the heating coil may also do the trick and here is less worry about overheating the wire) and the direct it down the drain about an inch or so.
The idea is that when the unit goes into defrost the wire will also heat up some and clear the ice at the drain hole.
Note: You do not want it to get too hot or it can melt the plastic liner.
ggrizzlys
#3 Posted : Saturday, June 19, 2010 6:12:54 AM(UTC)
ggrizzlys
Thanks for the info. will try. ggrizzlys
frezzer & fridge too warm (Refrigerator & Freezer Repair)
by NPANS 11/1/2016 10:15:58 AM(UTC)
exterior of panel between the frezzer door and the refrigerator door is burning hot (Refrigerator & Freezer Repair)
by splash13 7/19/2014 7:44:36 PM(UTC)
frige and frezzer not working. (Refrigerator & Freezer Repair)
by cewmsjw 10/30/2013 7:44:02 PM(UTC)
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 10/4/2012 10:09:15 AM(UTC)
ice on bottom of frezzer (Refrigerator & Freezer Repair)
by robertcall60 8/28/2012 5:46:32 AM(UTC)
frezzer not frezzing, refrigerator not staying cold, water driping in bottom pan (Refrigerator & Freezer Repair)
by sandra j hackney 7/9/2012 7:49:11 AM(UTC)
Fridge and frezzer are not getting cold (Refrigerator & Freezer Repair)
by Kevin Hutchens 6/24/2012 12:43:49 PM(UTC)
No ice, warm fridge, frezzer ok, frost build-up (Refrigerator & Freezer Repair)
by alltrees 6/16/2012 12:13:21 PM(UTC)
frezzer not frezzing food (Refrigerator & Freezer Repair)
by kjhluisa07 6/8/2012 2:03:01 PM(UTC)
Frezzer not Frezzing but still cold (Refrigerator & Freezer Repair)
by surgecast 4/4/2012 7:41:36 AM(UTC)
in frezzer door water line (Refrigerator & Freezer Repair)
by cgirl11@gmail.com 11/20/2011 3:37:45 PM(UTC)
by anitajones 7/22/2011 5:45:22 AM(UTC)
frig & frezzer (Refrigerator & Freezer Repair)
by jamesrt 4/13/2011 5:17:27 PM(UTC)
Warm Frezzer (Refrigerator & Freezer Repair)
by anfurnee 3/16/2011 3:18:43 PM(UTC)
