efalborn
#1 Posted : Tuesday, June 15, 2010 6:32:11 PM(UTC)
efalborn
my whirlpool duet dryer runs fine but will not heat up to dry clothes. does this sound like the heating element needs replacing or is it something else entirely.
any suggestions or advise, greatly appreciated.
#2 Posted : Wednesday, June 16, 2010 1:50:36 AM(UTC)
Replacement parts for WHIRLPOOL GEW9250PW1 Electric Dryer | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208558722.pdf
Cannot find a manual for a 9250 but here is one for a 9200 with a little luck it will be close to your unit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa/$FILE/Duetdry.pdf
Could be a number of things.
Try running the diagnostics perhaps it will help narrow it down.
Then try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord.
[COLOR="Red"]Be careful 240 volts is lethal.[/COLOR]
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
The thermal fuse for the heater is Item 47 in Section 3.
The high limit is also on the heater.
The cycling (control) thermostat is on the blower.
The thermal fuse on the blower is for the motor so is OK.
If the heater's thermal fuse is blown get back to us as there are other things that should be checked before replacing it.
Check the thermistor for resistance.
