AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore 90 series washer will agitate but not spin or drain
My washing machine goes all the way through the cycles, agitates and everything, but will not spin or drain. Help?
Originally Posted by: kmyres76 My washing machine goes all the way through the cycles, agitates and everything, but will not spin or drain. Help? Kenmore Model 110.20922990 Fills and agitates but will not spin or drain.
i discovered seconds before delivery of new Kenmore washing machine...that SWITCH very easy to see under the lip of the machine..needs to be replaced. I'm looking for HOW to do? I found the part. It looks easy, but looking for diagram and info....
I have MODEL 110 92480200 Kenmore Heavy Dute 80 Series..It works, it just needs a new switched installed and trying to see if I can do myself...any advice on "HOW To?" or shld I just call....Sears home repair....? The part is available..
Originally Posted by: jeanfix I have MODEL 110 92480200 Kenmore Heavy Dute 80 Series..It works, it just needs a new switched installed and trying to see if I can do myself...any advice on "HOW To?" or shld I just call....Sears home repair....? The part is available.. Hi, My washer is a Kenmore series 90, Model #110.20922990 and replacing the lid switch solved my problem. I don't know what differences there are between the series 80 and 90, but the following web site has photos and detailed instructions that include replacing the lid switch for a series 90 Sears Kenmore Washing Machine Repair I hope it may be of some use to you. My biggest problem was either waiting a week for the part to arrive or driving 100 miles to pick it up at a Sears parts center... I chose to make the trip. It only took about 15 minutes to replace the switch once I had it in hand. Hope this is of some use to you.
Washer Repair
