KacyS
#1 Posted : Tuesday, June 15, 2010 6:41:25 AM(UTC)
KacyS
Hello, my Kenmore side by side has stopped cooling after a power surge happened on Saturday. The breaker tripped 3 times and after that, it stopped cooling. Any suggestions on what to look for and how?:confused:
#2 Posted : Tuesday, June 15, 2010 9:01:57 AM(UTC)
Your compressor probably shorted out. You can confirm by checking the compressor terminals for a short to ground. Too late now, but I would add a 1000joule surge protector to the wall outlet.
KacyS
#3 Posted : Tuesday, June 15, 2010 9:54:33 AM(UTC)
KacyS
Thank you, Richappy. I will start there and see where it leads me. That is my "electric beer cooler" that can't break down! :) If I order a new compressor, is it easy to replace?
#4 Posted : Tuesday, June 15, 2010 1:36:25 PM(UTC)
The new, modern compressors are rather expensive and pros. charge a lot to put one in, also, you will not be able to buy refrigerant without a license.
KacyS
#5 Posted : Tuesday, June 15, 2010 3:14:08 PM(UTC)
KacyS
Well, there ya have it. Thanks again for your help!
Guest (6)
