i want to make sure i intsall new control board properly part #22004317.is there anything i need to know so i don't blow this new part it was $390.00 please help if possible thank you.....:confused: jt
Here is the service manual for the Maytag Neptune. Your model is discussed in detailed in extended discussion at the back of the manual. http://www.servicematters.com/m...ibrary/docs/16010061.pdfTreat the board as you would any other circuit board; also be careful for static electricity and make sure you are grounded before touching it.
