need of washer help2010
#1 Posted : Monday, June 14, 2010 4:33:02 PM(UTC)
My washer won't stop filling. It stops if I unplug it, but I do not hear the clicks when it goes from each level.
#2 Posted : Tuesday, June 15, 2010 3:13:50 AM(UTC)
I would pull off the clear plastic tube from the water level switch and force vinegar down it with a turkey baster; this will clean out the soap residue at the bottom of the tub bowl that it plugs into.
#3 Posted : Tuesday, June 15, 2010 12:19:31 PM(UTC)
that didnt work. It still won't stop. I can blow into the clear tube and hear bubbles being blown.
#4 Posted : Tuesday, June 15, 2010 1:40:26 PM(UTC)
You either have a hole in the tubing, or a bad water level switch.
#5 Posted : Tuesday, June 15, 2010 3:29:39 PM(UTC)
is it worth having someone else come and fix it?
#6 Posted : Wednesday, June 16, 2010 12:35:00 AM(UTC)
Pull the hose off the tub and blow in it, maybe the contacts will break free.
GE washer won't stop filling, agitate or spin (Washer Repair)
by nmoreno24 10/14/2016 6:57:55 PM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
GE Washer won't stop filling (Washer Repair)
by ddavis263 7/26/2010 1:53:58 PM(UTC)
by scrabs 1/17/2009 6:48:54 AM(UTC)
