My washer is 7 yo. and the plastic outer tub is cracked again at the same place as before near the suspension asm in the back right side. The noise is a screaming/knocking noise. Very hard to explain. When it cracks it leakes water out onto the floor. The washer seems to have a horrible noise during the rinse cycle. The noise gets louder when the washer is at a faster speed and as the washers cycle slows the noise lessens. Nobody can tell me what it is and it seems that everything from the inner tub to the direct drive motor has been replaced once just about a month ago.
