I would appreciate any suggestions. Three year old side by side unit stopped cooling on both sides. Compressor goes from hot to warm and doesn't seem to be vibrating. I hear clicking every so often. All fans operational both by compressor, frezzer and fridge. Cleaned lots of dust off evaporator coils under unit. Freezer coils are not frozen up and no frost. Removed start delay and replaced and it doesn't rattle. Should I assume the compressor is trash? possible it is something else like compacitor? or start relay even if it doesn't rattle?
Thank you, C
I eliminated a fair number of potential problems from all the good information available on this forum. And ended up replacing the Relay/capacitor Part Number: AP4079373. Though it has only been a couple hours, the fridge is down to 40 and the freezer is on it's way. The compressor has been running for the duration. Looks to be a home run. Enlarge Photo Relay/capacitor Part Number: AP4079373
I have mine that does not cool either. Can you tell me how you fixed yours
