stp57
#1 Posted : Sunday, June 13, 2010 5:21:08 AM(UTC)
stp57
The plastic housing on the inside of my dryer has become brittle & the pieces that have broken off snag the cloths. AppliancePro has the whole front for $80, but I would like to just replace the plastic or repair it. Any suggestions? Does the front panel come off easily?
Steve
Part Details - GEH FRONT PANEL WH, part number: AP4510255
stp57
#2 Posted : Monday, June 14, 2010 8:25:25 PM(UTC)
stp57
I just ordered the front panel for ApplianceParts. Does anyone here know how it is attached to the dryer frame? If it is clips, is there a special tool needed?
Steve
stp57
#3 Posted : Wednesday, June 23, 2010 7:14:48 AM(UTC)
stp57
I finally got the right part to replace but I still need to know if I need a special tool to take the front panel off? Is it held on by clips?
Steve
#4 Posted : Wednesday, June 23, 2010 10:21:33 AM(UTC)
Steve,
Which part did you order? The part number you posted earlier does not look like the right one.
stp57
#5 Posted : Wednesday, June 23, 2010 11:31:10 PM(UTC)
stp57
Thanks Gene for the interest. You are right, they did send me the wrong part. This is the correct part:
Part Details - GE Front air duct assembly, part number: AP3186270
I will still have to remove the front panel. Do I need a special tool, or there clips?
Steve
#6 Posted : Friday, June 25, 2010 4:57:22 PM(UTC)
No Steve, you do not need any special tools.
Open the door and remove the screws holding the top panel from the door frame.
Lift the top panel and remove the screw on each side holding the front panel.
Remove the front panel.
stp57
#7 Posted : Sunday, July 18, 2010 7:29:53 AM(UTC)
stp57
Thank you very much Gene. I can't believe how easy that was to change that part once I knew how to open up the dryer!
Steve
#8 Posted : Monday, July 19, 2010 6:48:47 PM(UTC)
You are welcome Steve. I'm glad you were able to fix it.
