Fxitpop
#1 Posted : 15 years ago
Fxitpop
GE Model PDS22SISRSS: Condenser fan not running. Replaced fan motor - still not running. Replaced Main Control Bd. - still not running. Does anyone know how to test the fan motor (UDQT24LG3) for this particular model? Does anyone have a schematic of the Main Control Bd (WR55X10416)?
#2 Posted : 15 years ago
You will need a meter to check things. Condensing motor gets 13 vdc from the motherboard J2 connector as measured between pin 5 and 8 (Pin 8 red wire, pin 3 white wire, pin 5 yellow wire at the motherboard)
Pin 5 and pin 3 is 6.3 volts; might be from a resistor or a semiconductor on the motherboard or it could even be a square wave as it is 1/2 pin 8 voltage.
You could check continuity. J2, pin 8 is red, pin 3 is white, pin 5 is pink at the motherboard and yellow at the condensing fan.
This is from a GE fridg schematic and of course GE could have changed the wire colors on yours!
Sorry, this is the best I can do. This is all gleaned out of the South Jersey publication that is no longer available to me.
