Hello, I recently posted this and was told maybe a thermal fuse. I just found out that I can find reset codes behind toe plate. I will check tomorrow. I have power to the control panel but no lights or commands are responding. Is there something else I can do? Im trying to find a schematic to locate the thermal fuse, since it is one of the less expensive parts to try. Thanks, James
THIS FORUM IS DEAD!!!!!!! |
