Jmsaufan
#1 Posted : Thursday, July 17, 2008 8:44:51 AM(UTC)
Jmsaufan
Rank:: Member
I have an Amana side-by-side refrigerator. The ice maker is producing only a small amount of ice. When I remove the ice bin and put it back, this seems to initiate the ice making process, but still only a little ice is made. Any advice greatly appreciated.:confused:
#2 Posted : Thursday, July 17, 2008 4:50:58 PM(UTC)
What is the temperature in the freezer?
Jmsaufan
#3 Posted : Tuesday, July 22, 2008 8:58:46 AM(UTC)
Jmsaufan
Rank:: Member
Hi, Gene. The freezer temp is 8 degrees F. I manipulated the ejector blades and more ice is being produced, but some of the cubes are hollow. As I watch the process, the hollow cubes appear to be coming from the right side of the unit(my right as I am looking inside the freezer). Cubes being ejected from the left side of the unit are pretty much solid.
#4 Posted : Wednesday, July 23, 2008 1:39:49 PM(UTC)
Normally the temperature in the freezer suppose to be between 0°F - 5°F. 8°F can slow down ice cube process.
Remove the front cover from the ice maker and turn the adjustment screw (on the side or the ice maker) CCW for about 90° to increase the amount of water coming into the ice maker.
