Hi, hoping someone can help me out! I noticed the other day that my dryer wouldn't start and after checking around on a few things I determined that the circuit breaker in my house clicked off. I turned it back on and now the dryer will turn on, but it doesn't have any hot air on any setting. I figured this out because I put a load of laundry in on the Auto Dry setting and the next morning the dryer had not turned off and the clothes were still damp. So my dryer won't heat and won't ever turn off after being started. Hopefully someone has an idea of what went wrong. Please Help!
2 things, you will want to verify you have 240 volts at the wall recepticle assuming this is an electric dryer, and also make sure the cord at the terminal block of the dryer is connected and that all wires look good. If those check out ok, it could be your heating element.
