AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
is this a water-inlet injector? can I use a generic replacement?
Have you seen the part pictured in the file attached (shown down at the bottom)? The closest ones I found in the catalog are Part number: AP4025626
, Part number: AP4023882
, Part number: AP4111389
, Part number: AP4025519
. Can I use any of them as a "generic" replacement? I'm guessing this part is called a "water-inlet injector". Here's my best description of it: it's a hard plastic part with a wide "head" or "cap" that stays inside the tub and a thin long cylinder "body" that sticks out of the tub where it's connected to a silicon flexible tube. The head broke off thus the tube is leaking. I found a related thread though I'm not sure I need all those parts (nozzle, injector valve, sleeve). Thanks! fgnievinski attached the following image(s):
Hi. Just wondering if anyone has the answer for my original question. Thanks!
I think I finally found exactly the part that I need: Part number: AP4546590
Unfortunately it's out of stock, though. I've placed an order anyways, hoping that I'll be suggested an alternative part. Perhaps a more recent version of the dishwasher model that I have would do it. -F.
Dishwasher Repair
