I have a loose upper sprayarm. If I replace the arm itself, will a new one stay put or is there apt to be a problem with the plastic pieces that hold it?
Gene, The sprayarm is for the third level, #570 on the diagram. It falls off with each washing. Have you had this problem before?
Hi ghcusic I do not remember how this spray arm should be mounted to the dishwasher, but I believe if you buy the new one you'll be able to figure it out. If you'll find it should be screwed then it's possible you have to remove the dishwasher from the cabinet. - The part number for the new 3rd level spray arm assembly AP3184058 Good luck. Gene.
