The first time we ran our self clean it shorted something out. Neither the baking or broiling element would work any longer. The oven will come on but they won't heat up. A repairman fixed it while it was under home warranty. We recently ran the self clean again and the same thing happened. I replaced the baking element but it still won't heat up. Is there a fuse or something that might have blown?
I saw a post from someone who had a double oven, same brand as mine. They were told to replace the thermal fuse and it appears that fixed the problem. Can I do the same thing with mine?
Thanks for all the great feedback, not. I figured it out myself. For any of you having the same problem you should replace the thermal fuse on the back panel of your oven. That should take care of it. Make sure you shut the power off first!
