I need help replacing the belt on the motor.
You will have to
1. Remove the front panel and release tension on the belt
2. Remove the motor with the pump assembly
3. Remove the pump
This will allow you remove and replace the belt.
Although it can be a one person job, the motor is heavy and awkard to remove and replace and I recommend having a helper.
Good luck, let us know how it turns out.
