BlazeMiller
#1 Posted : Friday, June 19, 2009 2:10:10 PM(UTC)
BlazeMiller
Electronically controlled Whirlpool WW2780W double oven: Start upper oven with keypad, set temperature and within about 30 seconds it turns off without heating up. Lower oven works fine. Any ideas?
Dan O.
#2 Posted : Saturday, June 20, 2009 3:48:43 PM(UTC)
Dan O.
Quote:
Whirlpool Double Oven...
WW2780W is the model number of a Jenn-Air oven, not a Whirlpool.
You mean the control resets to standby mode (ie. as if it hasn't been programmed to do anything)??
If that is what is occurring, I can't think of anything that would cause that besides a malfunctioning control.
LINK > Jenn-Air WW2780W Electronic Control (no picture)
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
BlazeMiller
#3 Posted : Sunday, June 21, 2009 8:53:38 AM(UTC)
BlazeMiller
:eek:Yes, Jenn-Air not Whirlpool
Yes, the digital touch pad resets as if you hadn't entered anything to turn it on.
:confused:When you say "control", you mean the timer- clock circuit board control behind the touch pad, correct?
Dan O.
#4 Posted : Sunday, June 21, 2009 12:20:34 PM(UTC)
Dan O.
Quote:
When you say "control", you mean the timer-clock circuit board control behind the touch pad, correct?
Yes the actual electronic circuit board unit. It contains the microchips which govern its actions.
JFYI
Dan O.
=D~~~~~~
BlazeMiller
#5 Posted : Monday, June 22, 2009 11:46:05 AM(UTC)
BlazeMiller
:) Thanks... will get it ordered..
Dan O.
#6 Posted : Monday, June 22, 2009 12:48:34 PM(UTC)
Dan O.
Let us know how you make out.
Dan O.
=D~~~~~~
