josolo
#1 Posted : 16 years ago
josolo
dryer works but no heat comes out. how do i find out which part to change?
#2 Posted : 16 years ago
Here is your wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528192.pdf
First turn the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter.
Next would be the heater itself and then it's thermal fuse.
GE Dryer down (Dryer Repair)
by Michael S 14 years ago
How to slow a dryer down (Dryer Repair)
by pcroyle 15 years ago
Gas Dryer Down-Checked top 5 sensors but no answers (Dryer Repair)
by BobG68 15 years ago
