halojm
#1 Posted : Saturday, June 20, 2009 8:16:54 AM(UTC)
halojm
Hello,
I have a nice double glass door (SNAIGE) brand fridge that I had brought back from one of my many trips to Afghanistan (Military) I have used it faithfully for years as my garage fridge. Unfortunatly due to my own stupidity while chipping away Ice build up ( I know, I know) I hit the freon line, which excaped all the R134 coolant. Is there a way to patch the tiny hole via poxy, and have the system recharged. Parts are very limited to find. And I just cannot get ride of the unit, to sentimental of where I aquired it. Any help please.
Thank you
Dumb Joe
#2 Posted : Saturday, June 20, 2009 11:10:34 AM(UTC)
If you unpluged the fridg. just after you did this, the compressor may be ok. If you let it run for a period, the compressor now has water in it which will make it fail eventually.
halojm
#3 Posted : Saturday, June 20, 2009 2:41:45 PM(UTC)
halojm
The unit was unplugged at the time. So will poxy work as a sealant
Eddie365
#4 Posted : Saturday, June 20, 2009 3:31:00 PM(UTC)
Eddie365
You can use poxy to patch the whole it should work but then then filter drier will need to be replace, pull a vacum and the recharge again.
