AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
GE dishwasher, water will not drain after rinse cycle.....
This dishwasher works fine through the wash cycle and drains ALL the water as I have checked it after the wash cycle is complete. The problem only occurs after the rinse cycle. When the dishwasher runs from start to finish on any wash cycle there is always approximately 1'' of water left in the bottom and the dishes do not seem to be as clean as they use to be. Any and all help will be greatly appreciated. Thank you.
Mike
THIS FORUM IS DEAD!!!!!!! |
I replaced the nut & piston and still have about an inch of water after the cycle is complete. Please let me know what to check next as your help is greatly appreciated. Thank yuo.
Mike
Check that the drain hose is looped up at least 10 inches higher than where it enters the house plumbing. This should eliminate any chance that it is siphoning back into the machine.
Check that the wash/drain flapper valve/solenoid is working correctly. Also some of the flapper valves have a hole in the center. This should be plugged with a black seal.
That is about all I can think of other than rechecking the pump impeller and drain to be sure that it is clear. |
Dishwasher Repair
