2 Pages12>
rcooks87
#1 Posted : Friday, June 19, 2009 1:28:47 PM(UTC)
rcooks87
I recently replaced the heating element but it still is taking forever to dry. I just started using a voltage meter and I think I'm using it right. Element checks out as good. I think I read the cycling thermostat could be the problem next. I tried checking it...the two terminals where the red wires attach show the piece is good. But if I touch the two terminals where the smaller purple wires connect to...it shows bad. Is this the problem or am I just not checking it right? Thank for your help.
Eddie365
#2 Posted : Friday, June 19, 2009 5:13:02 PM(UTC)
Eddie365
HI. First you should check for air flow.
make sure anough air is being discharge if not you vent house has to be plug up.
applianceman
#3 Posted : Friday, June 19, 2009 5:57:28 PM(UTC)
applianceman
The operating thermostat can be bad, but I agree with Eddie the dryer vent is the most likely cause for this problem. Make sure there is good airflow all the way outside. Clothes Dryer Repair Guide
rcooks87
#4 Posted : Saturday, June 20, 2009 2:04:54 AM(UTC)
rcooks87
I pulled the dryer vent off the wall and ran a cycle venting inside and it is no better.
rcooks87
#5 Posted : Saturday, June 20, 2009 2:14:22 AM(UTC)
rcooks87
but, when I check the operating thermostat with a volt meter it shows its good. Am I doing something wrong with the voltage meter?
#6 Posted : Saturday, June 20, 2009 3:21:38 AM(UTC)
Replacement parts for WHIRLPOOL LEC5000PQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
As you know you need heat and air flow for good drying.
When you had the unit off the vent did you check that the unit has both.
Does changing the temp setting do anything?
If not you have a temp regulation problem re: thermostat etc.
Air flow can be drastically reduced if:
1. Blower wheel is clogged with lint
2. Filter screen has a coating caused by fabric softener
3. Sometimes the blower wheel thread can strip
4. You are actually sucking the air past the heating coils and through the drum so if the drum seals are leaking you pull unheated air into the drum. Usually this will cause the temp fuse on the heater to blow because the operating thermostat on the blower sees a lower temp and causes the unit to overheat.
On the meter usage see below.
Your operating thermostat has an internal heater so with the unit unplugged and at least one side of the device you are trying to measure disconnected.
The contacts should read 0 ohms, use your most sensitive scale.
The internal heater should measure 7,000 ohms (see the wiring diagram).
METER USAGE
rcooks87
#7 Posted : Saturday, June 20, 2009 8:34:35 AM(UTC)
rcooks87
thank you for all your ideas. I can see you have really spent some time on this. I am at my wits end. I have vacumed every crack and cranny. Perhaps this model is just a lemon and takes 90 minutes to dry. I'm not clear why the thermostat checks out fine, the element checks fine. I took the venting out of the wall. I'm at a loss. You would expect a little less aggravation from a three year old machine. Any last thoughts anyone???
applianceman
#8 Posted : Saturday, June 20, 2009 8:42:36 AM(UTC)
applianceman
90 mins doesn’t seem that bad is your washer spinning out the clothes good? I mean they should be dry in 60-80 but 90 isn’t terrible. Make sure you are using the proper spin speed on the washer.
rcooks87
#9 Posted : Saturday, June 20, 2009 10:09:43 AM(UTC)
rcooks87
yes washer is doing its thing clothes are coming out of washer right. I just followed up on an earlier suggestion of running a load through the low heat cycle and seeing if there was a difference. No difference...clothes came out exactly the same on high heat or low heat...damp...It takes about two cycles either way to dry a load right...sometimes 3 if its a big load.
rcooks87
#10 Posted : Saturday, June 20, 2009 4:09:09 PM(UTC)
rcooks87
is an operating thermostat the same as the cycling thermostat and that part contains the internal heater?
Guest (8)
2 Pages12>
