westoconst
#1 Posted : Friday, June 19, 2009 8:08:11 AM(UTC)
westoconst
it was running fine, put new handel in hasn't run right sense
#2 Posted : Friday, June 19, 2009 2:25:07 PM(UTC)
Can you be more specific on the problem?
westoconst
#3 Posted : Saturday, June 20, 2009 1:20:37 PM(UTC)
westoconst
the washing motor runs about 2or3 seconds then stops for 10seconds does this 3 or 4 x's then panel shuts off . i cannot make electric water valve activate by using the manual function test. so i changed it out same result . i can make wash motor run with manual test but nothing else.
#4 Posted : Saturday, June 20, 2009 3:34:33 PM(UTC)
Make sure all wires are properly connected to the door switches and the black wire is hot while the white is neutral.
