jorgearteaga
#1 Posted : Thursday, June 18, 2009 6:46:28 PM(UTC)
jorgearteaga
when set temps are at there coldest. What are the temperature suppose to be reading with a digital thermometer.
woodchuckie
#2 Posted : Thursday, June 18, 2009 7:56:35 PM(UTC)
woodchuckie
The normal operating temp in a freezer should be around 5 or 10 degrees but should be able to go below 0 degrees. I hope this helps.
#3 Posted : Friday, June 19, 2009 3:59:39 AM(UTC)
Here is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/240389610.pdf
Does not give the answer to your question but does show mid-point specs.
