TREX
#1 Posted : Wednesday, June 17, 2009 8:46:11 AM(UTC)
TREX
I am replacing an evaporator motor using kit 482468. First, the instructions say to attach the mounting plate to the motor using the included screws. The actually fits over two threaded studs off the motor. No nuts are included in kit. No problem, hardware store item. My big problem is the hub in the kit doesn't fit the motor shaft !?! The shaft on the new motor is too big for the small hole in the hub. Is there another hub available ?? The instructions mention nothing about this. ( yes, I had to read the instructions!)
any help appreciated.....:confused:
#2 Posted : Wednesday, June 17, 2009 5:11:00 PM(UTC)
What is the complete model number of the refrigerator?
TREX
#3 Posted : Wednesday, June 17, 2009 8:33:04 PM(UTC)
TREX
I am not sure why I need the model of the fridge....but I will get it and post it in a.m. My problem is the hub supplied in the repair kit doesn't fit the motor shaft from the kit !
#4 Posted : Wednesday, June 17, 2009 10:26:12 PM(UTC)
We need the model number to provide most accurate advice and to verify the part number for the evaporator fan motor in your case.
TREX
#5 Posted : Thursday, June 18, 2009 8:45:15 AM(UTC)
TREX
model no. 106.6654602
motor # from parts breakdown in owners manuel - 530314
thanks,
#6 Posted : Thursday, June 18, 2009 1:05:51 PM(UTC)
The hub included in the kit must fit the motor shaft. If it does not then it is probably defective. People who sold it to you have to exchange it under the parts warranty.
TREX
#7 Posted : Thursday, June 18, 2009 8:12:02 PM(UTC)
TREX
I bought it from this web site ,AppliancePartsPros.....Can I return it for an exchange?? Thanks for you assistance!
#8 Posted : Thursday, June 18, 2009 9:05:30 PM(UTC)
I do not work for Appliance Parts Pros. You have to talk to the customer service.
