lastcast33
#1 Posted : Thursday, June 18, 2009 9:22:58 AM(UTC)
lastcast33
Hi, After a lightning strike my display malfunctioned on my convection oven and also giving me an F-5 code. I replaced the electronic control assembly/clock display. Now the display is working fine but I sstill get the F-5 code. My next step was to replace the relay board. Anyone know anything else I may be able to check on this unit? Thanks!!!!
#2 Posted : Thursday, June 18, 2009 1:30:22 PM(UTC)
According to the Service manual the "F5" error code means "Power element relays disabled in cook mode". The manufacturer recommends to check the oven sensor and its wire harness first. If there is nothing wrong then the relay board has to be replaced.
- The part number for the relay board is AP4095668
- The part number for the oven sensor is AP4009009
Here are the breakdown diagrams and Replacement parts for JENN-AIR W30400B | AppliancePartsPros.com
lastcast33
#3 Posted : Friday, June 19, 2009 3:22:10 PM(UTC)
lastcast33
Thanks a ton Gene. Looks like its the relay board.
#4 Posted : Friday, June 19, 2009 11:10:01 PM(UTC)
lastcast33
#5 Posted : Tuesday, June 30, 2009 12:40:12 AM(UTC)
lastcast33
Gene, You are the man. The relay board got us up and going again. Thanks!!!
#6 Posted : Tuesday, June 30, 2009 7:04:08 PM(UTC)
I'm glad to hear you are back in business. Good job.
