smkur50
#1 Posted : Wednesday, June 10, 2009 6:59:09 AM(UTC)
smkur50
Just bought the washer that was supposed to work..:rolleyes:
Anyway now I'm stuck with it and it seems to do everything but not spin. So, I pulled the top, front cabinet, agitator, tub etc. I can plug it in and see the clutch drum spinning but the tub shaft doesn't move. Then I notice the brake shoes are missing? Everything else seems to work but if the brake shoes are missing would that prevent the tub from spinning?
smkur50
#2 Posted : Wednesday, June 17, 2009 7:09:27 AM(UTC)
smkur50
Well, installed new brake shoes and hardware. Tub started spinning then stopped. Seems as though the clutch is slipping. I tried a washer but the clutch won't grip enough to spin tub. Guess I'll order the clutch kit.
#3 Posted : Wednesday, June 17, 2009 7:43:09 PM(UTC)
What is the complete model number of the washer?
