gratio
#1 Posted : Thursday, December 27, 2007 5:39:28 AM(UTC)
gratio
Electric Maytag Performa dryer, about 7 or 8 years old has started making odd noises on start-up. A week ago it started making a loud thud when as the drum reached full speed.
Now, when you hit the start button, it makes a rattle like something is loose and spinning, then the drum starts turning, then it makes the loud thud then runs fine. (all of this takes about 2 seconds).
Other than these noises at start-up it runs fine, heats, drys, does everything like it should.
Any ideas what could be happening or about to break?
#2 Posted : Thursday, December 27, 2007 12:31:27 PM(UTC)
Sounds like you blower is loose on the motor shaft.
vze82pkr
#3 Posted : Monday, December 31, 2007 7:40:54 AM(UTC)
vze82pkr
Rank:: Member
My dryer is make loud noises when it start up.:mad:
gratio
#4 Posted : Friday, February 1, 2008 5:01:52 AM(UTC)
gratio
Thanks richappy, it turned out to be the blower wheel. The hub of the wheel was completely rounded out. Replaced it and the dryer runs much quieter now.
