georgepannier@sbcglobal.n
#1 Posted : Wednesday, December 26, 2007 3:57:00 PM(UTC)
Im sure that this is a belt problem , my problem is that I cannot figure out how to get to the belt , how do i repair this .
#2 Posted : Thursday, December 27, 2007 3:43:58 AM(UTC)
Belts don't squeak but bearings do. Go to www.applianceaid.com for tear down info. You will probably find a worn drum center bearing.
misterfixall
#3 Posted : Thursday, December 27, 2007 7:02:24 PM(UTC)
misterfixall
check white pulley on idler arm. also check condition of the four glides around door bearing ,also door bearing itself
ripleys
#4 Posted : Friday, December 28, 2007 9:23:12 PM(UTC)
ripleys
A dry rear bearing ground strap will cause an annoying squeel also. Could lube with a high temp grease to stop noise. Have to pull the drum to get at it.
