whytegroup
#1 Posted : Tuesday, June 16, 2009 11:05:42 AM(UTC)
whytegroup
I need to replace the Control Board on my GE built in double oven. The Part Number is #PS238580. The disclaimer on the site which I found the part stated that the wiring might be different than the original Control Board. Are there any special instructions to replace the Board?:confused:
Dan O.
#2 Posted : Wednesday, June 17, 2009 1:50:31 PM(UTC)
Dan O.
Quote:
GE built in double oven Control Board Part Number PS238580
That would be AppliancePartsPros part number AP3155969.
LINK > GE JKP45WA2WW Electronic Control
If the replacement board requires any wiring changes there should be an instruction sheet included with the part. GE however is famous for supplying incomplete information which can sometimes make it a headache to install depending on the changes necessary. :rolleyes:
Whether this particular replacement board requires any drastic changes and/or the documentation for those changes are adequate in your case I don't know and I doubt anyone can tell you without seeing both the replacement control, the original control and the instructions at the same time.
If you don't think you can install the replacement part when you get it you can either return it or call in a technician to complete the job for you.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
