kenblarsen
#1 Posted : Wednesday, June 17, 2009 4:47:46 AM(UTC)
kenblarsen
The water leaks all over my floor and creates a mess. Any suggestions?
woodchuckie
#2 Posted : Wednesday, June 17, 2009 5:33:35 AM(UTC)
woodchuckie
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Post your model number if your need diagrams to find it.
kenblarsen
#3 Posted : Sunday, June 21, 2009 8:33:22 AM(UTC)
kenblarsen
Good advice,
Clearing the drain tube at the top and bottom seems to have fixed the leaking problem. Thanks
