kevinw3
#1 Posted : Monday, June 15, 2009 12:04:33 PM(UTC)
kevinw3
Recently the oven has been displaying an F3 error code. It would work on and off for a few minutes, but the code would shut it off. Just recently it stopped working all together, and now it won't even heat when set in bake mode. The top heating element still gets hot when the oven is set to broil though. I know that the F3 error code means that one of the sensors may be faulty. If anyone can give me some instructions on how to reach the sensors that would be fantastic.
Dan O.
#2 Posted : Monday, June 15, 2009 1:34:28 PM(UTC)
Dan O.
Quote:
Maytag Oven problems Model Number: ARDS802E
Isn't that an "Amana" branded appliance?
Also, in addition to the model number we would also need its manufacturing (MF G) number to identify it. It should start with the letter "P..."
That is most often caused by a problem with the oven temperature sensor (see the following link).
LINK > How do I check an oven temperature sensor?
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
