pairington
#1 Posted : Monday, June 15, 2009 6:45:47 AM(UTC)
pairington
It is getting more common that the stove top burners and the oven will not heat up. Could it be the electronic range control]
Dan O.
#2 Posted : Monday, June 15, 2009 7:01:42 AM(UTC)
Dan O.
The elements won't heat *at all*? Not even get warm??
Do they all stop at exactly the same time?
It usually has nothing to do with the surface elements so if they're all malfunctioning at the same time and in the same way, it would be safe to say the control is not the cause of the problem.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
