Piita
#1 Posted : Sunday, June 14, 2009 7:48:40 PM(UTC)
Piita
I have a Whirlpool LE5720XSWO. The dryer started taking longer and longer to dry a load, then finally quit heating altogether.
I replaced the heating element yesterday, turned the dryer on and it heated up, no problem. Today I dried a load of clothes, and at the end of drying, the dryer was incredibly hot and the clothes were too hot to touch.
I have read that the problem is probably the thermostat, but when looking at your parts list, #6 on the diagram is listed as the Cycling Thermostat; #7 and #15 are listed as the Thermal Cut-off and High Limit Thermostat. In this scenario, which thermostat most likely needs to be replaced, the Cycling Thermostat or the High Limit Thermostat? If I have to replace both, can I just order Item #6 and Item #15, the t-stats only, and skip Item #7, the Thermal Cut-off?
Please advise, thanks so much!
#2 Posted : Sunday, June 14, 2009 11:33:17 PM(UTC)
The first thing I would do is clean the vent all the way to the outlet and make sure the lint chute (#1 on the diagram) is clean and the blower is working properly. Usually all dryers overheating due to obstructed air flow.
Piita
#3 Posted : Monday, June 15, 2009 4:20:18 AM(UTC)
Piita
Thanks, Gene! The vent is clear, this was done at the time the element was replaced. That is why I'm concerned...I don't want to order the Thermal Cut-off Kit if all I need is the High-Temp or Cycling T-Stat.
FYI, the dryer does progress through a timed cycle and cut-off on its own, and it does still get hot, so the Thermal Cut-off and/or Fuse doesn't appear to be blown.
#4 Posted : Monday, June 15, 2009 5:43:47 PM(UTC)
Did you check the lint chute and the blower wheel?
