philfrommaine
#1 Posted : Wednesday, December 26, 2007 10:25:04 AM(UTC)
philfrommaine
I have an OLD GE Washer WWA8320G whose agitator is slipping. Spins and drains water perfectly, but agitating cycle does not catch the agitator (motor actually working). If manual physical pressure is applied to the top of the agitator is "catches" and agitates. Is this a problem with the stem (male) that fits into the plastic agitator or could the molded grooves in the agitator have worn out, or is there some other potential issue?
#2 Posted : Wednesday, December 26, 2007 10:50:38 AM(UTC)
It could be the agitator spline (#303 on the #5 break down diagram) or the transmission shaft.
What exactly is wrong could be find only after a visual inspection.
- Here are the break down diagrams for the GE washer Model WWA8320GAL
Happy New year!
philfrommaine
#3 Posted : Wednesday, December 26, 2007 12:57:40 PM(UTC)
philfrommaine
Thanks Gene - appreciate it -
beekay519
#4 Posted : Saturday, December 29, 2007 7:54:45 PM(UTC)
beekay519
Phil ----
I would check the drive belt. When was it last changed?????? If not the belt, check the plastic agitator hub before tearing into it further.
philfrommaine
#5 Posted : Monday, December 31, 2007 7:34:10 AM(UTC)
philfrommaine
Thanks beekay519 - agitator spline referenced by Gene above did the trick - a challenge getting the old one out, but with some persistence and pounding with a nail punch it finally kicked out -
thanks again all who responded
#6 Posted : Monday, December 31, 2007 8:55:52 AM(UTC)
I'm glad you were able to fix it.
Happy New year!
