tashley
#1 Posted : Saturday, June 13, 2009 11:31:20 AM(UTC)
tashley
Washer did not drain completely and could hear spin cycle motor running.
It would not spin properly. Looked on bottom of washer and belts were loose. Belts looked good. Observed that you could move motor back and forth, but it would not apply tension. Has two springs. Are springs weak? What could be the problem?
applianceman
#2 Posted : Saturday, June 13, 2009 3:36:47 PM(UTC)
applianceman
The belts are supposed to be loose and what you describe about the motor sounds ok. I would look for something blocking the pump or drain first.
Clothes Washer Repair Guide
