AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
My ice maker quite working then later water dispenser doesnt work
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Originally Posted by: Marino7213  i dont hear the valve opening when the button is pushed in how do i get to the despensor switch to replace it? i have had trouble before with the switch not wanting to work all the time. sometimes you would have to push it in two or three times before it would finally work so i took the panel off of the front of the freezer where the ice and water come out and the switch for the water despensor was out of place and the bracket was broke off. when you push the switch the water comes out great. thank you for all the help i will definatly keep this website in my favorites for future use and tell lots of people about it. again thank you
i recently had trouble with my ice maker not making ice, i contacted yall and yall walked me threw it step by step thanks again. but now every time it makes ice it trys to dump the ice and it gets the ice out of the trays but its gets stuck before they fall and to repeat the process, any advice on this on?
