2 Pages<12
woodchuckie
#11 Posted : Friday, June 12, 2009 7:33:40 AM(UTC)
woodchuckie
Originally Posted by: DaveCon Go to Quoted Post
I have the same problem....no water. I had my freezer door replaced and all seems to work except the water. I watched it being done and it looks like all was put back exactly the way it was on the old door. When I push on the dispenser I can hear a click from the dispenser, then a moment later from what sounds like the back of the fridge....but nothing comes out. I don't think the line in the door can be frozen because it is a new door. Doesn't seem like any water coming in - haven't seen any ice made in the last few hours. Also to note my filter has not been changed for a long while, could that have anything to do with this mystery? Anyone have other ideas...Help!
Replace the filter and see. If it still doesn't work, make sure the water supply is not stopped up at the screen filter in the water inlet valve. The water inlet valve is where the noise comes from on the back. You can disconnect the water line coming out of the valve and try the dispenser to see if the valve is working.
2 Pages<12
