jhall82891
#1 Posted : Tuesday, June 9, 2009 5:35:35 PM(UTC)
jhall82891
Drier stops when you release the start switch. It will run through complete cycle if you hold the start switch on.
#2 Posted : Wednesday, June 10, 2009 3:14:21 AM(UTC)
Replacement parts for GE DBXR463EB1WW | AppliancePartsPros.com
Note: getting tech info on GE's off the net is difficult to say the least.
Do you have the wiring diagram?
If not open up the control console and take a look, they like to store the diagrams in there.
The diagram will show you what closes to hold the unit on when the start switch is released.
Often this is one of the centrifugal switches on the motor but there are other methods used.
When you hold the start switch closed do you get heat?
If not then odds are high that the mechanism in the motor which closes the centrifugal switches is not working.
One switch removes the motor's start winding from the circuit and may hold the unit on when the start is released. The other, switches on the heating element.
Here is a good link with basic info. Check out the GE section, there are some typical wiring diagrams available here
http://www.applianceaid.com/dryers.html
jhall82891
#3 Posted : Wednesday, June 10, 2009 9:05:25 AM(UTC)
jhall82891
The GE Drier works fine if you hold the start switch on through the cycle.
I tape the start switch to on position and it works fine, but would like
to use it in the proper manner.
deeboy31
#4 Posted : Thursday, June 11, 2009 6:20:00 PM(UTC)
deeboy31
when instart the dryer it goes and then it stops after trying to start it again it want we have to let it sit a while before it starts again
#5 Posted : Friday, June 12, 2009 3:18:20 AM(UTC)
deeboy31
Please start your own thread in this forum using POST NEW TOPIC, be sure to include the Make and Model.
Your problem is different from jhall8891's and being part of their thread will just confuse things
Thank you
