ray1216
#1 Posted : Thursday, June 11, 2009 3:17:46 PM(UTC)
ray1216
Need help to understand where I need to install a 46 puron piston on condensor, this unit has the liquid line and suction line flare adapters missing? Do I need to install a piston, if a TXV is installed on coil?
fhvac
#2 Posted : Friday, June 12, 2009 9:03:26 AM(UTC)
fhvac
no the tx valve is the piston
icehouse
#3 Posted : Sunday, June 14, 2009 2:40:07 PM(UTC)
icehouse
Manufacturer's no longer want flare fittings, they want sweat. Puron is Carriers name for R 410A, which only uses TXV's. :)
