longhornp
#1 Posted : Wednesday, June 10, 2009 8:20:23 PM(UTC)
longhornp
I have a whirlpool side by side frig with the ice maker in the door. It worked great for the past 7 years until one day came home to water/ice all over the freezer. I cleaned it up and defrosted etc but ever since then it has not made ice. I replace the ice maker assembly, the control module, and the ice sensor. Still no luck. What else could it be that is pretty much all the components of the ice maker. Running out of ideas.
woodchuckie
#2 Posted : Thursday, June 11, 2009 4:41:48 AM(UTC)
woodchuckie
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
