iamatke
#1 Posted : Wednesday, June 10, 2009 12:28:18 PM(UTC)
iamatke
Sorry to be redundant with this post. I have tried switching wires at the inlet valve. It is a dual valve with two connectors on each one. Each valve has a two position red connector and a two position white connector. I tried switching both connectors from one valve to the connectors on the other valve. I get water at the door either way. My question is, after switching the connectors, shouldn't I have gotten water at the ice maker when the door water switch is activated??
woodchuckie
#2 Posted : Wednesday, June 10, 2009 12:52:24 PM(UTC)
woodchuckie
You are correct. I think there is a problem with the water inlet valve.
iamatke
#3 Posted : Wednesday, June 10, 2009 3:50:44 PM(UTC)
iamatke
Woodchuckie:
Which of those connectors should be switched?? White ones, red ones, or both?? Also, the icemaker is removed. Will the valve work if that is out??
woodchuckie
#4 Posted : Wednesday, June 10, 2009 5:06:18 PM(UTC)
woodchuckie
Swap both connectors and the valve will work without the ice maker.
iamatke
#5 Posted : Wednesday, June 10, 2009 5:44:02 PM(UTC)
iamatke
just so I am clear, I am swapping white on one valve with white on the other valve and swapping the reds also?? Or am I supposed to swap the white with the red on one valve.
woodchuckie
#6 Posted : Wednesday, June 10, 2009 7:20:14 PM(UTC)
woodchuckie
Swap the white with white and red with red. Good luck.
