jslujanljpb
#1 Posted : Wednesday, June 10, 2009 3:57:58 PM(UTC)
jslujanljpb
Water dripping into ice bin and eventually freezes in bottom of ice bin.
Could this be a gasket or seal? Any help would be great! Thanks, Jerry.
woodchuckie
#2 Posted : Wednesday, June 10, 2009 5:10:36 PM(UTC)
woodchuckie
If it's dripping from the water mold and it's not overfilling I have no knowledge of any opening it could leak through.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and divert the water into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
