Jon V
#1 Posted : 17 years ago
Jon V
I found a small hole, about the size of a ballpoint pen point, in the bottom of my dishwasher which has created a leak. What would be the best way to patch it . It's right below the heat coil.
Thanks, Jon V
misterfixall
#2 Posted : 17 years ago
misterfixall
sometimes i will cut a small piece of plastic from margerine top ,clean and dry area ,place over hole, dab silicone glue on top and spread evenly .let dry 24 hours
#3 Posted : 17 years ago
Silicone cement will not last on vinyl tub. Best to use a real vinyl cement. Check at a hardware store or Lowes.
Also, if the hole is acessable, use some glue and a chrome screw.
misterfixall
#4 Posted : 17 years ago
misterfixall
there was no mention that the tub is plastic
Jon V
#5 Posted : 17 years ago
Jon V
Thanks, Jon V
Thanks for the help. I did the Mrfixall patch and used aquarium silicone which I've used on my hot tub. I guess the dishwasher tub is plastic, I'm not sure what else it would be. I will be doing a Christmas day test drive, I'll let you all know how it goes. Again thanks to all and have a wonderful holiday.
Jon V
Jon V
#6 Posted : 17 years ago
Jon V
Thanks to all, leak has stopped. I guess I'll cover the patch with vinyl cement just to make sure....Thanks again, Jon V
