allen9258
#1 Posted : Monday, December 24, 2007 4:15:01 PM(UTC)
allen9258
dryer won't turn sometimes and other times it will here are some of the problems that plague this dryer when it does work it will run for a short while then shut itself off, and when it doesn't you can push the start button and it will humming sound then it acts as if a relay switch cuts the power because it will not start for about 30 seconds afterwards you are able to try and start it again.
#2 Posted : Tuesday, December 25, 2007 5:00:48 AM(UTC)
You have a blown motor, bad bearings/start winding.
Guest (4)
