at the end of the wash cycle, it does not drain the water out. The pump is okay, so is it in the motor ? board ? capasitor ? or what do you think??? oh, at that point it doesn't do anything else, then goes off and back to start.
The first thing I would check is the lid switch (#11 on the top and cabinet break down diagram). Remove the control panel, unplug the wire harness and check continuity across the lid switch terminals. It should be closed when the lid is closed. Replace if it's open. - The part number for the lid switch is AP3020600 Gene.
